Had a great call with one of our Veras users, and went through an Rhino exercise for creating renderings from the massing models. Below is our exploration and some of the Q/As.
Building you Render
- add details to base model
- windows, levels / floors (can be just linework), colors
- add materials to the base model
- using colors close to the material helps with identifying where the prompt should place those materials
- ex: brown for wood, and blue for glass
- this also helps AI find where to allocate the material separation onto the geometry
- build your prompt gradually
- render one phrase, then add another, then render
- add materials, weather, lighting
- emphasize parts of the render when needed with parenthesis
- ref: Prompting Glossary - #2 by Ben
- settings
- start with high geometry override and keep a balanced prompt strength, when there are less details in the model
- as you add details to the model, decrease the geometry override, and increase the prompt strength
- getting the final render
- run at least 4 renders per setting
- once you find a sweet spot in the settings for your view, run 10-20 renders to cherry pick the best one
Q/A
- is it possible to distinguish context buildings and main building with colors (or tricks)
- it also helps to add some schematic information, like the stories, or windows
future version will have a region based prompting
- should I insert people, trees and window to render them?
- Having some geometry resembling these elements allows the algorithm to allocate the prompt to the geometry
- can I give picture as references / style as reference?
Not at the moment – we can add this in the future
Renders
Geometry Override : 83
Material Override : 100
Width : 1216
Is Aerial View : ON (other toggles OFF)
Prompt : exterior shot of utopian architecture building with cinematic lighting by zaha hadid and renzo piano, darek zabrocki and greg ruthkowski, alphonse mucha, simon stalenhag, cinematic, stars, beautiful, holy place, paradise, scifi, futurism, atmospheric, sunset, concept art, artstation, trending on artstation
Prompt Strength : 81
Geometry Override : 52
Width : 1216
Geometry Override : 91
Width : 1216
All Toggles : OFF
Prompt : newly developed area with buildings featuring wooden facades, large windows, and a tress along the street, design by Ludwig Mies van der Rohe
Width : 1216
All Toggles : OFF
Prompt : neo brutalist herzog & de meuron bioremediation, architecture installation, philip beesley, art
Width : 1216
All Toggles : OFF
Geometry Override : 80
Width : 1216
Prompt Strength : 100
Width : 1216
Width : 1216
Width : 1216
