The light is scattering a lot for the same prompt. No consistency of lights. Ceiling lights are of no use as the AI does not considers it for lighting in the scene. Kindly guide for light control in the scene.
Thank you for the additional data.
The material override is set to 10, which makes the render use a lot of the data from the base image. So if the base image has more lighting information that could influence the render output. For example, the lights could have a white material in the base image.
Beside that, we have limited control over lighting with our app at the moment. We will be releasing updates that will allow for more granular control, and we will make workflow posts about how to improve this.
If you can share the base image (original image), that will help us with testing the new features.
