Helix Roadmap | AutoCAD ⇌ Revit
Features & Ideas
We’d like to share with everyone the more common feature requests that are now logged in our backlog. Please let us know if there are features you’d like to see in this outline. Also, if you see a feature you feel strongly about, let us know so we can prioritize it more.
Legend
:white_check_mark: [x.x.x.x] feature completed and deployed with version number
:building_construction: we’re working on this feature now (soon to be released)
:clock3: planned features that we will work on after the next release
DWG ➔ Revit
BIM Elements
  • :white_check_mark: [2.2.4] Plumbing Pipes from DWG Revit Link (alpha)
  • :white_check_mark: [2.4.0] Plumbing Pipes (improved)
  • :white_check_mark: [2.5.0] Room Separation Lines
  • :white_check_mark: [2.5.0] Walls
  • :white_check_mark: [2.5.0] Railings
  • :white_check_mark: [2.7.0] Windows
  • :white_check_mark: [2.7.0] Doors
  • :white_check_mark: [2.9.0] Columns and Structural Columns
  • Floors
  • Roofs
  • Structural Grids
  • Structural Framing
  • Ceilings
  • Light Fixtures
  • Topography
  • Wall Openings
Meshes
  • AutoCAD Civil 3D Topo Mesh Support
Automation
  • :white_check_mark: [2.5.0] Detect centerlines from double walls
  • :white_check_mark: [2.7.0] Detect doors & windows in walls and heal walls from 2d floor plan
  • :white_check_mark: [2.7.0] Place doors and windows in walls
  • :white_check_mark: [2.12.0] Map detected wall widths to specified wall type
  • :white_check_mark: [2.12.0] Map detected door & window widths to closest type size
  • Set pipe slopes
  • Map detected door & window widths to instance parameters
  • Map standalone block to family
  • Add a block compensation angle to align the block and family orientation
  • Detect standalone block size and link to family parameter
  • Map doors and windows without needing a cad block
  • Work with multiple selected files at the same time
  • Automatically adjust “element is slightly off axis” angles using a tolerance
UI/UX
  • Select tool for easy mapping
  • Highlight selected maps for clarity
  • Status report for DWG updates
  • Show layer colors in the mapping table
  • Optimize speed for centerline detection
Details
  • Convert Details to Revit Drafting Views
    • Line Mapping with Revit Lines & Line Patterns
    • Hatch Mapping with Filled Regions
Hi Ben,
Really interested in seeing where this tool goes, our company has some dynamo scripts that create a bi-directional flow between AutoCAD and Revit for our MEP schematics, would you be interested in a discussion around this and we could feed-back what might be useful from an MEP perspective?
@nico.brown definitely! I’ll send you a DM with my email.
Also, welcome to the forum!
Definitely looking forward to the structural framing feature. This would be included in my workflow IMMEDIATELY
