Helix - Release 2.15.1
To install the latest version, please click the link above.
- Updated the primary color to improve legibility in Revit
Bugs
- Error message when loading Helix in 2025
Ben
3
Helix - Release 2.15.2
Stability
- Fix mapping disappearing when closing then re-opening the SketchUp Helix UI in the same session
- Fix Helix Hub bug where the port would not be available for communication
Daniel
5
Helix - Release 2.15.3
Stability
- Fixed bug where some DWG layers with very small lines would not convert to Revit elements.
- Fixed bug causing some Helix Revit functions to crash if the Helix Hub is not running.
- Other development updates, to make working on and fixing Helix bugs easier
Helix - Release 2.15.4
Stability
- Fixed an issue where Helix was not loading properly in Revit 2026
