Helix login problem from Sketchup
I tried to login in helix from Sketchup the same way I logged in Glyph in Revit (I have full apps license) but is not working, not even a error message, after inputting the email and password info, it just do nothing, all clean to fill in the info again.
@dacFSDCOL - welcome to the forum!
It seems like we missed your post. (We were most likely at the Trimble Connect conference when this was posted)
Do you still have an issue with login?
If yes, please make sure that you are using the latest Helix release. If that fixes the issue great! Otherwise, @Daniel should be able to further assist.
@dacFSDCOL,
Were you able to log into Helix?
If not, can you post a screenshot or gif or what you see when you try to open Helix inside of SketchUp? Also, can you please let us know what versions of Helix and SketchUp are you using?
If you’d like, you can send me your email in a private message on here, and I’ll look into your account specifically and see if I notice anything amiss.
