Glyph - Release 3.6
Download: Installer
Features :tada:
Search bar
Quickly locate your tasks and bundles or add new ones directly from the Glyph library.
Search bar
Get Started Buttons
New intuitive buttons to help you jump into core workflows and explore Glyph’s capabilities:
  • Create views
  • Tag
  • Dimension
  • Guided Tour
  • Glyph AI Assistant
    Example
Expanded Library
  • 27 New Tasks added to the default library.
  • 5 New Bundles added for streamlined workflows.
UI Settings persistency
Your workspace now stays exactly how you left it. The following settings are now saved between sessions:
  • Language Preference
  • “Get Started” visibility
  • Report/Bundle Report toggles
  • Active mode
Revit 2027 support
Full compatibility for the latest Revit release.
3D Room View – View Rotation
New settings for more control over your 3D Room View rotations.
Improvements :roller_coaster:
Bugs :bug:
  • Bundle Tooltips: Fixed an issue where the Run button tooltip didn’t provide instructions when an assembly task was included.
  • Parameter Setter: Resolved a bug preventing the setter from modifying Phase parameters.
Guides :memo:
GLYPH 3.6.0.1
To install the latest version, please click the link above.
  • Automatic Family Selection: The “Interior Elevation” view family type is now automatically selected when creating elevations by room. This prevents the use of “Building Elevation” types, which are limited to one view per elevation marker.
Bugs :bug:
  • Fixed an issue with placing views on sheets when the initial view exceeded the available space.
  • Fixed a bug where the glyph would get stuck while dimensioning or tagging if the view had not yet been opened.
  • Assembly Naming: Fixed a UI error that occurred when multiple assembly views were created with identical names.
GLYPH 3.6.0.2
Bugs :bug:
  • Fixed an issue with setting trials in the UI and backend.
GLYPH 3.6.0.3
Bugs :bug:
  • Fixed an issue tagging structural framing elements.
it states working with the 2027 but it detects only till revit 2026
can u fix the installer please
@hobz.94 Thanks for letting us know, we’ll look into it.
I was able to reproduce the issue with Glyph 3.6.0.3.
We’ll let you know when we figure it out and have a fix!
@hobz.94 I believe we have figured out the cause of the bug, and are working on a fix.
Revit 2027 changes where it looks for addins, and Glyph was not being installed in the correct post. I was able to manually move the files, and then Revit 2027 picks it up:
Once we have an updated installer, I’ll post it here.
If you are interested in the temporary work around I used, please let me know and I’d be happy to share it!
Yes i would be glad if u can share it with me until the fix is out :folded_hands:t2::folded_hands:t2:
@hobz.94
Just move these two things:
  • EvolveLAB.Glyph.Revit.addin (file)
  • Chaos.Glyph (folder — move the whole thing, contents included)
From here:
C:\Program Files\Autodesk\Revit 2027\AddIns\
To here:
C:\Program Files\Autodesk\Revit\Addins\2027\
Hello, I’ve tried that but I still cant open glyph, I’m using Revit 2027.2
@skap Thanks for letting us know - we are working on a release that will fix this Revit 2027 support bug. It should be included with the next release of Glyph. We’ll post in this thread ones it’s out!
GLYPH 3.6.0.4
Bugs :bug:
  • Glyph was hitting an error (with a long message) immediately following the launch of the addin in Revit 2025 and 2026, preventing normal use of the addin for some users. This is now fixed.
  • Glyph now installs to correct location for Revit 2027, and is visible in Revit’s ribbon.
GLYPH 3.6.0.5
Improvements :sparkles:
  • The Glyph installer is now signed by Chaos. Windows will show “CHAOS SOFTWARE EOOD” as the publisher.
Bugs :bug:
  • Signing in to Glyph with an expired trial, or with an account that has no Glyph license, showed an error instead of a clear message. Glyph now shows the correct “No License Found” / “Trial Expired” message.
GLYPH 3.6.0.6
Bugs :bug:
  • Fixed bug that prevented Glyph, or Revit, from closing, if multiple people have edited the Glyph tasks/bundles in a workshared model and not synced yet.
