Glyph - Release 3.5
Download: Installer
Features :tada:
Dimensioning
New Grouping Option:
Wall Core Exterior/Interior Reliability:
  • Improved the reliability of Core Exterior and Core reference detection.
Zero Value Suppression:
Assemblies
Sheet Creation:
  • New setting to create sheets either inside the assembly or outside as standard Revit sheets in the Project Browser.
Elevation Views:
Improvements :roller_coaster:
  • Tagging: Added support for “Tag End” elbow conditions in plan, elevation, and section views when “Attached End” or “Free End” is set.
  • Persistence: The Active Mode value property is now saved between sessions.
  • Annotation Collision: The “Crop View” setting no longer needs to be enabled for annotation collision detection in plan views.
  • Performance: Optimized filter speed by 50% on large models; improved element collection efficiency when filters are applied.
  • Workflows: Extended view orientation configurations to assembly-based view creation workflows.
  • UI/UX: Improved task icon sizing and refined dimension setting tooltips.
  • Logic Refinement: Enhanced annotation collision detection metrics and element filtering logic.
Bugs :bug:
  • Fixed Active Mode not disabling when turned off within the task itself.
  • Fixed an issue where changing the UI language would affect the View Family Type selection.
  • Fixed new tasks not working properly when Active Mode is on.
  • Fixed Active Mode not acting correctly when creating a new bundle.
  • Fixed annotation collision for elevations with negative right directions.
  • Fixed custom task icons affecting the name width of tasks inside a bundle.
  • Fixed an issue where duplicating a task would not update Active Mode.
  • Fixed adding a new task from the library not updating Active Mode.
  • Fixed adding a new task from Copilot not updating Active Mode.
  • Fixed custom reference names being linked to each other when duplicating a task.
  • Fixed wall elevation orientation when the wall is not flipped.
  • Fixed manual element selection to reset properly when the category is changed.
  • Fixed elevation marker settings showing up during 3D view creation.
Guides :memo:
GLYPH 3.5.0.1
To install the latest version, please click the link above.
Bugs :bug:
  • Fixed room dimensions not dimensioning to the wall finish.
  • Fixed a bug where views were not retrieved when a filter was applied to the selection list in a bundle and the element selection was set to “Output from Previous Task”.
