Glyph - Release 3.2
Download: Installer
Features :tada:
Active mode
Automatically selects your active view or sheet in Revit, so you don’t need to open the task and choose it manually.
Setting
Active mode
Note: For first-time Glyph users, this setting is enabled by default, and elements are automatically selected from the start.
Improvements :roller_coaster:
Dimensions
Missing family references: When a family doesn’t have all the references selected in the UI, it will continue with the families that do have all the references instead of erroring out.
UIUX
  • Map views with Sheets Mapper: Retains selection when closing and reopening the UI
    Mapper
  • Library UI improved
  • Improved Status Report UI, differentiating bundles vs tasks
  • Improved By Line mode dimension UI
  • Language button:
  • Tabs dialog is now also used for managing tasks (easily delete tasks and bundles)
    Deleting tasks/bundles
  • Adding a new task will automatically place it in the active tab
  • The active tab is preserved when switching from Status Report / AI Assistant to the list of tasks/bundles
  • Filters now work with linked elements
  • Glyph AI Assistant will now automatically prefer to run a task (vs creating a task) based on the prompt when only the Glyph AI Assistant UI is opened
Bugs :bug:
  • Fixed spaces, wires, electrical circuits, duct insulation, and pipe insulation elements not getting tagged
  • Fixed structural foundation dimension error (non-negative index issue when dimensioning wall foundations)
  • Fixed the following dimension options for the walls category not tying to the correct reference (exterior/interior)
    ○ Exterior rough opening dimension
    ○ Exterior wall center opening dimension
    ○ Building dimensions
  • Fixed wall section dimension offset not working properly
  • Fixed Element selection option not getting copied when duplicating a bundle
  • Fixed bundle Run button tooltip when a task is added
  • Fixed bundle Run button tooltip not updating correctly when selecting or deselecting elements
  • Fixed bundle not working properly when a filter is applied at the same time as the Element selection option is set to “Output from previous task”
  • Fixed ceiling or floor dimension errors when elements are pinned
  • Fixed reuse dimension setting being enabled while the dimension is pinned
  • Fixed layout templates being “linked” when duplicating a task or bundle
  • Fixed UI not refreshing automatically when adding new tabs
  • Fixed Import Sheets by Spreadsheet not working in 2025/2026
  • Fixed linked view creation based on rooms duplicating views when there were multiple RevitLinkInstances of the same Revit link model in the project
  • Fixed linked element views not being placed correctly on the correct sheet when selecting multiple linked rooms
  • Fixed CSharpAnalytics package error when multiple versions of Glyph were open
Coming Soon :alarm_clock:
  • Assemblies support
Guides :memo:
GLYPH 3.2.0.1
To install the latest version, please click the link above.
Bugs :bug:
  • Fixed an issue where the Place Views on Sheet task did not place Structural Plans or Area Plans when the filter was set to “Structural Plan” or “Area Plan”.
