February 8, 2024, 5:17pm
View Crop Offset - Additional settings
Bugs
Fixed filter value incorrect when saving the same categories twice
Fixed curtain wall dimensions showing 0β 0"
Fixed filter not working when the parameter value is null
Fixed dimension offset not working for negative values
@Miguel After updating to 1.3.2.0, there seems to be a bug in creating sheets from Rooms, where the plugin shows an error when trying to set sheet parameters.
I tested this on a new blank project to check and got the same results.
App Log below for reference:
February 15, 2024, 2:19pm
3
@surajsankar , thanks for the feedback. We will fix this bug and include it in the next release.
February 16, 2024, 9:17pm
4
GLYPH 1.3.2.8
To install the new version, please use the link above.
Bugs
Fixed Glyph ribbon tasks not working without opening main Glyph window
Fixed add filter errors when adding parameter setter
Fixed offset not working for βby lineβ dimensioning mode
Fixed licensing issues
Ben
February 16, 2024, 10:52pm
5
Neat update!
I like the new sign in UI
