Glyph - Release 0.8.0.0
Features :tada:
  • Automatic Annotation Collision
    • Tags and dimensions will move automatically until an empty space has been on your view. This will increase legibility as well as decrease the time you spend moving tags/dimensions
    • Available for all the “tag and dimension” tasks
    • New setting
      • image
    • Examples:
    • Things to know:
      • View cropbox must be turned on
        • View cropbox can be visible or invisible. See image below for reference
        • image
      • If you can’t see the tags in an elevation/section, please check the annotation crop setting of the view
Hi Miguel, great update! thanks.
Are you able to change the category “Tag” to a Multi Category Tag? We use this for all of our FF&E items.
Hi @mitchellaxisa !,
Not yet but we have it on the backlog and we will add it to Glyph soon. I will let you know once it is available
I love this release!
I took your images @Miguel and turned them into gifs:
2023-02-27 - 16-58-06
2023-02-28 - 12-41-34
Glyph - Release 0.8.0.1
Improvements :roller_coaster:
  • Annotation Collision Avoidance
    • New Setting “Max offset from element”
      • image
    • Speed:
      • 15% faster
Bug Fixes :bug:
  • Fixed Room finish schedule creation not recognizing room parameters
Glyph - Release 0.8.0.2
Bug Fixes :bug:
  • Fixed Room finish schedule creation errors when more than 10 filters are added to the schedule
  • Fixed view creation cropbox taking into account large sections crossing the view. This will make the viewport bigger than it has to be when placing views on the sheet.
    • image
  • Fixed annotation crop offset when creating views
Glyph - Release 0.8.0.3
Bug Fixes :bug:
  • Fixed tasks not saving to the projec
  • Fixed creating bundles not working properly
  • Fixed exporting task/bundles not working properly
  • Fixed importing task/bundles not working properly
Glyph - Release 0.8.0.4
Bug Fixes :bug:
  • Fixed “room height” setting not working properly when using this setting in a Revit model that uses metric units
    • Setting located in the “Create views by room” task inside the view type “Elevation” image
  • Fixed view name cutting off inside the “Map views with sheets” setting
  • Fixed room elevations not cropping to room separators/boundaries
  • Fixed filtered items only displaying the name of the view/sheet/room instead of the UI friendly version.
    • Before: “Area A floor plan”
    • After: “Floor Plan: Area A floor plan”
  • Fixed view parameters only showing view template parameters in some scenarios. For example: view name parameter wasn’t available in some cases.
  • Fixed bug where views were not getting placed on sheets when a viewport type without a title and line was selected
Thanks @Miguel! Awesome work.
