Revit View Setup
Follow step #1 in this post for the view setup: Rendering Exteriors in Revit
1 | Faceted Facade
All the renderings below have the same settings including the prompt:
Creativity Strength: 100
Style Strength: 38
Width: 768
Is Interior: OFF
Turbo Nature: ON
Atmospheric: ON
Aerial: ONPrompt: articulated facade, rectilinear, high contrast, surfaces with sharp edges and sharp corners, reflective and matte mosaic surfaces, glass and steel, designed by daniel libeskind, white sky, faceted facade, golden hour, white walls
2 | Voronoi Facade
All the renderings below have the same settings except for the prompt. See prompt below each render.
Creativity Strength: 95
Style Strength: 34
Width: 768
All toggle settings are OFF
Prompt: articulated faceted facade with voronoi fractalization design, designed by olafur eliason, creek, lush
Prompt: articulated faceted facade with voronoi fractalization design, rectilinear, sharp edges and sharp corners, designed by olafur eliason, in a busy city at night, with traffic
Prompt: articulated faceted facade with voronoi fractalization design, rectilinear, sharp edges and sharp corners, designed by olafur eliason, in a busy city at night, with night traffic
Prompt: same as above
3 | Surface Mix Facade
Creativity Strength: 82
Style Strength: 48
Width: 768
Turbo Nature: ON
Aerial: ON
All other toggle settings are OFF
Prompt: articulated facade, rectilinear, high contrast, surfaces with sharp edges and sharp corners, concrete matte mosaic surfaces, concrete and steel, designed by daniel libeskind, white sky, faceted facade
