Render Engine 7 and 7 Flash have opened up a number of new workflows. These have been highlighted in the release post but I wanted to dig a little deeper and provide some specific examples.
Render Floor Plans
We can now take an empty plan and populate it with furniture. Render Engine 7 will understand rooms and populate with appropriate furniture.
Prompt:
Edit the provided floor plan image to add realistic, appropriately scaled furniture to every room.
Keep the original floor plan geometry exactly the same: do not move walls, doors, windows, labels, or room dimensions. Preserve the black-and-white architectural drawing style.
Add furniture using a clean, top-down architectural rendering style, aligned to walls and centered logically within each room. Maintain clear walkways and realistic spacing for human movement.
Furnish rooms as follows:
• Living Room: sofa, accent chairs, coffee table, side tables, media console, rug
• Kitchen: cabinets, countertops, appliances, island or dining table if space allows
• Bedrooms: appropriately sized bed, nightstands, dresser, optional chair
• Bathrooms: vanity, toilet, shower and/or tub
• Office: desk, chair, storage
• Laundry Room: washer, dryer, shelving
• Closets & Pantry: shelving and storage systems
• Garage: parked vehicle footprint and storage/workbench
Ensure all furniture fits within the labeled room dimensions and does not block doors or windows.
Use neutral tones and subtle shading so furniture is clearly visible but does not overpower the floor plan lines.
Transform the Floor Plan into a 3D Dollhouse with Materials
We can even take the best result and convert it to a colorized 3D Isometric View.
Prompt:
Convert this 2D floor plan into a clean 3D dollhouse view: extrude walls, add basic floors and furniture, remove labels, use an isometric cutaway perspective with soft daylight.
Edit Materials
We can now try out different material. Typically these changes would take a lot of effort to put together. But with Render Engine 7 we can ideate quickly, and have confidence we are moving in the right direction.
Prompt:
Edit the provided image by replacing all existing carpet, rugs, and flooring materials with new materials.
Maintain the exact same layout, furniture, walls, cabinetry, fixtures, lighting, colors, proportions, and camera angle.
Do not alter or move any objects, furniture, doors, windows, appliances, or architectural elements.
Ensure the new flooring follows realistic material behavior, including correct seams, grain direction, reflections, shadows, and transitions between rooms (bathrooms, kitchen, bedrooms, garage if applicable).
Match lighting, perspective, and scale perfectly so the flooring replacement looks photorealistic and naturally integrated into the scene.
No changes beyond flooring materials.
Transforming Basic Models into High Quality Rendering
We can take even the most basic models and develop an incredible quality rendering.
Prompt:
Edit the provided architectural CAD model image to produce a photo-realistic architectural rendering.
Do not change the camera position, angle, focal length, or framing. The perspective, proportions, and alignment of all edges and structural lines must match the original CAD model exactly.
Do not modify geometry. Keep all building forms, rooflines, walls, windows, railings, decks, columns, and terrain exactly as modeled. No additions, removals, or reshaping.
Upgrade only the materials, textures, lighting, and rendering quality to photo realism while keeping materials similar in color and intent:
• White walls remain white stucco or plaster
• Red roof remains a red standing-seam metal or similar
• Wood volumes remain wood siding
• Glass remains clear architectural glazing
• Metal railings remain dark metal
Add realistic surface detail such as texture variation, subtle imperfections, reflections, shadows, and global illumination. Use physically accurate daylight, soft natural shadows, and realistic sky lighting.
Preserve the exact structure lines so the rendered image can be overlaid perfectly on the original CAD model.
The final result should look like a professional architectural visualization of the same building, not a redesigned or reinterpreted version.
Add realistic Detail/Entourage using the Sketch tool
If you do not have it already, start by enabling the Sketch tool through Settings, then Experimental Features. Then just use the tool to draw a simple shape around where you want this feature to be added.
Here are the results, cohesive ideas that compliment the rendering.
Prompt:
Preserve the original image exactly as-is. Do not change the camera angle, perspective, architecture, materials, lighting, or overall composition.
Add a small, realistic patio in the flat grassy area directly in front of the wood-clad wall, integrated naturally into the existing slope.
Patio details:
– simple concrete or stone patio surface, flush with the ground
– a low retaining wall that steps gently with the terrain
– clean, modern detailing consistent with the architecture
Add minimal outdoor furniture on the patio:
– a small table and a few chairs or lounge seats
– furniture scaled realistically and placed naturally
– neutral, contemporary materials
Ensure the patio feels naturally constructed on the site:
– correct ground contact and shadows
– smooth transition between grass, retaining wall, and patio
– no changes to the existing building footprint
Do not add new structures, decks, roofs, or pathways. This is a subtle site addition only.
Photorealistic architectural visualization.
You can even change the time of day without modifying the model.
Night shot – starry sky
Prompt:
Preserve the original image exactly as-is. Do not change the camera angle, composition, architecture, materials, landscaping, or any objects in the scene.
Transform only the time of day to a realistic nighttime setting.
– Replace the sky with a clear, natural starry night sky
– Adjust overall lighting to nighttime exposure
– Add subtle, realistic artificial lighting where appropriate (soft interior glow through windows, minimal exterior lighting)
– Maintain realistic light falloff, shadows, and reflections
The scene should feel calm, believable, and photorealistic.
No redesign, no added elements, no stylistic effects.
Sunset / golden hour
Prompt:
Transform only the time of day to a realistic golden-hour sunset with a rich, varied sky.
Sky and atmosphere:
– layered sunset sky with color variation, not a uniform tone
– natural gradients of warm golds and ambers blending into soft pinks, muted purples, and cooler blue tones higher in the sky
– subtle cloud formations that catch different colors at varying heights
– realistic atmospheric depth and light scattering
Lighting:
– low-angle sunlight with warm highlights and long shadows
– balanced contrast, avoiding over-saturation
– believable reflections and color bleed on surfaces
The result should feel cinematic yet natural, like a real sunset observed on site.
No redesign, no added elements, no stylization.
Change Season and retain accuracy
Fall season Prompt:
Preserve the original image exactly as-is. Do not change the camera angle, composition, architecture, materials, site layout, patio, terrain, or object placement.
Transform only the season to fall / autumn by modifying the appearance of existing vegetation only.
Allowed changes (appearance only):
– recolor existing tree leaves to autumn tones (yellows, oranges, muted reds, remaining greens)
– reduce leaf density slightly to suggest seasonal change
– subtle fallen leaves on the ground originating only from existing trees
– slightly less saturated grass color
Strict vegetation rules:
– do not add any new trees, shrubs, bushes, or plants
– do not increase vegetation density
– do not invent background trees, silhouettes, or tree lines
– treat trees and plants as fixed geometry; only change color and density
Maintain realistic autumn daylight and atmosphere.
Any change that adds or alters vegetation geometry is not allowed.
Winter season Prompt:
Preserve the original image exactly as-is. Do not change the camera angle, composition, architecture, materials, site layout, or patio geometry.
Transform only the season to a realistic winter setting.
Environmental changes only:
– trees without leaves or with sparse winter branches
– light snow coverage on the ground, roof, and landscape (not excessive)
– cooler overall color temperature with soft winter daylight
– subtle frost or snow accumulation in natural areas
Site adjustments:
– remove all outdoor furniture
– keep the patio intact and visible, lightly dusted with snow if appropriate
Ensure all changes feel natural and physically believable.
No added elements, no redesign, no seasonal decorations.
