Error setting parameters when creating new views
Good Morning,
Loving the plug-in so far. Having an issue in glyph with getting a few of the parameters to set when running the Create Views by Level workflow. Using the Trial Version in Revit 2024 in this case.
Phase and Phase Filter throw up an error that StorageType is elementId.
Also, when trying to add the Scope Box parameter it is giving me none in the dropdown selection even though i have one in my project.
Thanking you in advance for any insight.
Hi @jrhoe,
Thanks for the feedback! We will look into the “phase” parameter set issue and implement the change in the next release.
The scope box parameter cannot be set in the parameter setter, so we created the "Create views by scope box " task.
Hello, are there any updates or work arounds for this? It would be extremely nice to be able to pick the phase or phase filter when creating views. Especially since ‘Phase’ cannot be set by a view template. Thanks!
Hi @tbrozovich, you will be able to set the phase parameter starting Thursday with the release of Glyph 3.6.
Thank you for the feedback!
