@Rys Are you seeing the same “Error getting license” message mentioned in the posts above, or something different? I’ll send you a private message to get your email address, so I can try to look into this for you!
Edit: @Rys - Are you referring to the “login loop” issue in your other post, or is this a separate issue?
