Issue when a floor has been used to model a flooring type (carpet) on top of the actual floor (conc. slab) - the elevation view creator identifies the carpet as the top extent of the view and you end up with elevations that look like this:
Thanks for the response, and for adding this to the bug list.
Your workaround would work in theory, but the Room Height setting doesn’t seem to take into account that the ceiling is a room bounding element. i.e. If the room volume is modelled @ 2.9m tall, and your room bounding ceiling is at 2.7m tall, the tool reads the actual height of the room volume, not the bound height. I assume it’s reading the Limit Offset parameter of the room and applies that - this is an issue I also encountered when I was trying to make a very similar tool to Glyph for my team using Dynamo.
