Dimension Views by Category - Issue with Dimensioning plumbing fixture from finish floor height
Hi Miguel,
I am trying to dimension plumbing fixtures; measuring the height from floor level to the top of the plumbing fixtures in elevation.
But no dimension appeared..
Here is my setting :
Under status report it says as per the image below. But in my family, i have indicated Top reference plane in the said family. Anything else i am missing? :
Appreciate your advise
My machine config: Revit 2025, Glyph 3.2.0.1
@massrazz,
Under “Dimensions Created,” what do you see? This log is just a warning indicating that some of the families you are trying to dimension do not have the “IsReference” property inside the family set to “Top.”
Thank you,
