I am setting up a simple task to tag my curtain walls in plan views but am hitting some snags. I set up a task and filters to target only curtain walls that have a ‘mark’ value and place the appropriate tag type. However, after running the task I notice that many of the walls did not get tagged and cannot figure out why. In the plan view attached, curtain walls SF-28 and SF-26 that did get tagged are the exact same family type as all of the other curtain walls that did not get tagged. I am unsure what is causing this behavior and any insights would be helpful.
I went back into the project to rerun the task and was unable to replicate the same issue. It might have just been a bug within that session of Revit. It all appears to be working as expected.
Thank you for testing it again. We will keep an eye on it to make sure this doesn’t happen again.
Thanks!
