Copilot not finding correct room
Using Copilot commend was:
“Create elevations room 170”
Response was “Task “Create elevations based on rooms” was created. To run this task, I will be using the following rooms: 170A - CLASS LAB PREP”
It doesn’t appear to be finding the rooms asked for. Another example asked for room 165 and Copilot came back with 165A.
Hi @rwilhoit,
Thank you for your feedback! Copilot typically selects the first matching elements from the list, so it performs best when the request is very specific. Have you tried including both the room name and room number in your request?
Yes I have with no luck. Does the room number need to be “165” with quotes?
The room number doesn’t need to have the quotes.
I am planning to do further testing this week regarding this bug and release a new update Monday morning.
I will let you know my findings when the release is out.
Thanks again for reporting this bug!
