, but when I click on the model, it still shows as an Import Symbol property. This is preventing me from modifying or viewing the properties of the objects.
Could you please provide a solution for this issue?
Do you have a screenshot of what it looks like? What do you mean by the import symbol? Are you referring the the pipes generated as import symbols, or are there no pipes generated?
I have inserted a DWG file into Revit to convert it into Revit families. However, even after using your tool to create elements, the model still displays as an “Import Symbol” and the pipes remain unselectable.
