I’m having trouble logging in to try out Glyph. When I click the button it prompts me for an email address, but when I enter my address it gives me an error, “That email address is not correct”. I assume this has to do with our non-typical top level domain. Any suggestions?
After looking into the issue, you are correct that it is because of your email domain. Our current service doesn’t allow the top-level domain (anything after the final dot) to be longer than 5 characters, which is a bit outdated.
I’ll work on updating this and getting it included in an upcoming Glyph release.
In the meantime, the easiest way for you to use a Glyph trial would be with a different email address with a 5-charecter-or-less top-level domain, do you have access to one? If not, we could set up a temporary email for you that would allow you Glyph trial access, please let me know if you’d like to go this route.
Thank you for your patience as I work on resolving this.
