Someone reached out and wanted to know if Veras could help with biophilic design, specifically if Veras could create heavy planting and foliage as part of the building facade without necessarily having to model it in Revit. I did some tests. Here are the settings and prompts I used as well as some of the results:
Creativity Strength: 95
Style Strength: 41
Width: 1344
Turbo Nature: On
Atmospheric: On
Prompt: Modern biophilic architectural building, photorealistic rendering, modern black finishes, parametric architecture, mountain background, biophilia, soft light glow, parametric undulating balconies, plants growing on balconies, clematis vines growing on building, (((Biophilic design))), biophilic architecture, trees, green space, biophilic design, golden hour, soft lights glowing from inside building
Original Revit Model
Veras Output
Veras Output
Veras Output
Veras Output
Veras Output
Veras Output
Veras Output
Veras Output
Veras Output
