When will Archicad 29 be supported?
Since Veras is now fully integrated within Enscape, we recommend using Veras inside Enscape. Veras will support existing versions of ArchiCAD and Vectorworks, but new versions of these apps will not be directly supported by Veras for now. This might change in the coming months, but for now all new versions will work via the Enscape integration.
Thank you Ben, and yes, I will drop the standalone version and opt to use Veras integrated inside Archicad. Cheers
Im trying to install Veras for archicad 29 in my MAC but I can’t. I moved the downloadd folder after opening it, to the Add-On library, I can see it in the list but I’m not able to add it.
@iguana_design26 - welcome to the forum.
You can use Veras inside of Enscape by opening Enscape first. We don’t have a ArchiCAD 29 build of just the Veras plugin.
We have access to Veras via our V-ray Premium-sub, but do not have access to Enscape. Would be great if the addon could be updated for Archicad 29.
Are you using Windows of Mac for ArchiCAD?
If windows, I can send you a test build.
