Animating Construction using Revit Sample Model
This workflow demonstrates how to use Veras to animate the construction of a project using the Revit sample model. It is more for illustrative purposes.
Note: For a more accurate construction animation, we would need to setup the visibility of the items more accurately.
1. Setup Revit Visibility
2. Render with Reference
3. Render Reference & Visibility
  • unhide the floors and use the previous stage as a reference
  • repeat this for all of the other stages: hvac thru finished project
Bonus: Can make a night shot!
Then we have 6 image:
2026-04-17 - 06-29-27
4. Create Videos
  • go to the video tab
  • make a video of each start and end frame and pick which video is the best. 6 frames = 5 videos
  • you can do this by selecting the first frame to be the previous video’s last frame and so on and so forth
    2026-04-17 - 07-00-07 - ImageGlass
5. Combine the videos
  • I prefer to favorite the videos that are final
  • then select them all
  • then click the COMBINE button (which is usually the RENDER button):
6. Final Output
