The shape of my building is angular, I tried running the automatic dimensions on it but it doesn’t seem to be working. What can I do?
Hi @oluseyiadara ,
Glyph does dimension walls at an angle but doesn’t dimension curved walls. For Glyph to create a dimension, you will need at least 2 walls with the same angle.
Are you getting any errors?
Thanks!
