For the past 3 hours, and still now, a render service error, any updated when it will be fixed?
I’m sorry to hear that - can you please provide a script with the error? Also, are you using a VPN?
Hi, no i am not using VPN, the script goes-
Render failed due to the following error:
Error: veras render service error
You can share this issue with us and see if a solution has already been developed by visiting the forum.
Are you using the web app or a plug-in? What version of the app are you using?
1.7.11 plugin
I just played with the paramrters and there is a strange thing:
If i use material override less the 90, it gives me an error message again. Only above 90 it creates a render.
But this morning i worked with material override 0, and it did great renders. Why cant i use zero any more? With such high material override i loose so much of the originality…can you help with that?
