3d Mode for Revit 2023 and 2024 Bug: Error in Base App
Error: Error in Base App
Error has occurred where Veras integrates with dotNet
sync model error: Can only import models from Revit 2023 or later, location: at EvolveLAB.Veras.Utilities.ModelExportRevit.ExportObj() at EvolveLAB.Veras.UI2.UI.WebUiPage.<>c__DisplayClass46_0.<b__0>d.MoveNext()
@abdelsattar Can you let us know what version of Revit you were using Veras with?
I believe (@Greg or @Ben correct me if I’m wrong) that the ‘3D’ mode is only currently supported for Revit 2023 or newer.
Hello @Daniel . Yes, this is the truth.
Hi Daniel, it happens even when in 2024. How can I fix this issue?
Kind Regards
Strange, thanks @HO6N for the additional info. I’ll look into this with Revit 2024 and see what I can find out!
Buen dia he tenido el mismo problema usando revit 2024 encontraron alguna solucion?
Has there been a solution for this? I am also experiencing this with Revit 2023 and 2024.
@jdefelice Oh man, I don’t think we’ve figured this one out yet! Haven’t reproduced this on my end, which makes it harder to solve, but I’m hoping we will have a fix published soon!
I updated Enscape and then it seemed to solve the issue
hello, i use revit 2023 and i want to try veras for render. But i have a problem after downloaded. When I try to switch to the 3D tab, I encounter the error in the image. I deleted and reinstalled the program, but the error persists.
@dllsu - thank you for bringing this up. We were able to reproduce the bug, and we will have a patch released shortly. It seems like if users are using Revit 2024 and below, this bug appears. Revit 2025 and 2026 is working.
This is now resolved in the latest 3.1.0.1 patch: Veras - Release 3.1 - #2 by Ben
Please let us know if there are any issues with your testing.
