Video Combine not possible
Issue Combine video files in Veras
When attempting to combine two video files in Vegas, an issue occurs that prevents the process from completing successfully. Various settings and alternative methods have already been tested, without success.
Could you please let me know if this is a known bug in the current version and how this can be resolved?
Weird, let me look into this and do some more testing and get back to you!
Alternatively, I’ve recently been using a local AI agent with FFmpeg, which is great for combining, cropping, speeding up videos, and so on, and I think it’s all done via commands (which is why it’s easy for agents to use, I think). Just a workaround in the meantime you can try, while I’m looking into this!
@DEM8X I was able to reproduce this error, and I think I’ve found the cause. It seems like you are not able to selected multiple videos at once in the Video tab’s thumbnail bar in most browsers. I’ll work on a fix and get back to you once it’s released! Hang tight!
@Daniel - OK, no problem - :slightly_smiling_face:
Another update: We made a fix that seems to be working, but it’s still in the testing stage.
I’ll try to post again here once it’s released!
Another update: A fix for this has been approved! It will be included in the next Veras release. So, anything higher than the current version (5.3.3.0) will have this fix.
Hello Daniel,
Thanks for your time and the update.
This fix was included with the 5.4 release from a few days ago!
