Veras 5.3 - Nodes
Access
Veras 5.3 adds NODES, a new tab where you build your own workflows by wiring nodes together. A workflow can generate and edit images and video, analyze them, build parametric 3D geometry and bake the result into Revit, Rhino or SketchUp. An agent can build a workflow for you, any setting can become a simple control, and every workflow saves itself to your library.
:jigsaw: NODES — Build Your Own Workflows
NODES is a node canvas. Each node does one job, such as uploading an image, writing a prompt, generating an image, removing a background or making a video, and wires carry each result on to the next node. Press RUN GRAPH and Veras runs the whole chain.
The nodes:
  • Inputs: Image, Images, Video, 3D Model (.glb), Text
  • Values: Number, Toggle, Choice, Seed, Math
  • Generators: Image Generator, Video Generator, 3D Generator, Remove Background, Rotate Image, Post Process
  • Analysis: Describe Image, Depth Map, Canny Edges, Detect Objects, LLM
  • Combiners: Text Concat, Video Combine, GIF
  • Geometry: Building, Box, Extrude, Boolean, Array, Transform, 3D Preview, Capture View
  • Outputs: Save 3D Model, Bake to Revit, Bake to Rhino, Bake to SketchUp
  • Utilities: Reroute, Watch, Note
The generators use the same engines as the IMAGE, VIDEO and MODEL tabs, including reference images, first and last frames, and video editing on the models that support them. A few nodes to try:
  • LLM answers a question about text, images or a video using GPT-6 Astra or Claude Opus 5.5. For example, it can write a prompt from a reference photo. You pay for what the answer actually uses, and the node shows an estimate before you run.
  • Detect Objects finds the objects in an image that match your words. It outputs the annotated image, a crop of each object and their labels.
  • Post Process grades an image with the Edit-mode sliders. It runs on your computer, is free and updates as you drag.
  • GIF turns a video or a set of images into an animated GIF, and Video Combine joins clips into one video.
Adding nodes:
  • Drag a node in from the pane’s NODES list, or click it to add it at the center of the canvas
  • Right-click or double-click the canvas to open the Add menu, with search and your recent nodes
  • Drag a wire out into empty space. The menu lists only the nodes that accept what the wire carries, and wires the one you pick
  • Drag an image or video from the workspace strip onto the canvas to use it as an input
Running a workflow:
  • RUN GRAPH shows what the run will cost before you press it, and Veras asks you first before an expensive run. Each node shows its own cost as well.
  • Results show up as each node finishes. They land in the workspace one by one as soon as they are completed.
  • Up to 4 cloud jobs run at a time. The rest wait their turn and are marked Queued.
  • Unchanged nodes aren’t run again. Veras reuses their last result, so editing a prompt near the end of a chain only re-runs what it affects. A node whose inputs changed is marked Stale until it runs again. Run all in RUN GRAPH’s menu runs everything from scratch.
  • Fast, free nodes update live as you edit: values, Post Process and the geometry nodes. You can turn this off with Auto-run fast nodes in RUN GRAPH’s menu.
  • Stop one node or the whole run, and re-run a single node with its ↻ button
  • If a node fails, a message at the bottom of the canvas names the node and the reason. Show takes you to the node and Copy copies the full error.
Editing:
  • Undo and redo are on the toolbar, and also work with Ctrl+Z and Ctrl+Y
  • Ctrl-click or Shift-click to select several nodes. Space collapses the selected nodes and Ctrl+M turns them off.
  • Click a wire to add a Reroute dot and tidy a long wire, or right-click a wire to delete it
  • Watch shows whatever flows through it: text, a number, an image, a video or a model. Note adds a note to the canvas, with Markdown formatting and four colors.
NOTE: NODES is in Beta.
:robot: The Nodes Agent — Describe It, It Builds It
The pane’s AGENT tab works like the agent on the MODEL tab, but it builds workflows instead of models.
  • Describe what you want, for example “render my sketch in three styles and make a short video of each”. The agent adds the nodes, wires them, sets them up and puts the key settings in CONTROLS.
  • It can run the graph and look at the results. It asks you first before a run that costs 25 credits or more, or one that would go over the session’s budget.
  • Point it at nodes by selecting them. The message field shows a chip with your selection so the agent knows which nodes you mean. Click the chip’s ✕ to send without it
  • It keeps up with your changes. Anything you change on the canvas between messages is passed to the agent, so it works from the graph as it is now.
  • Each agent edit is one undo step
  • Sessions are saved with the workflow. To continue a conversation, open the ⋮ menu at the end of the pane’s tabs and choose Restore session…
The Nodes agent uses the same models and pricing as the agent on the MODEL tab. That includes the launch promotion while it runs.
:control_knobs: CONTROLS and OUTPUT — Turn a Graph into a Tool
CONTROLS collects the settings that matter in one place. You can change a prompt or a slider there without looking for it in the graph.
  • Pin any setting to CONTROLS with the ⊕ that appears when you hover over its row
  • Drag a node onto the CONTROLS pane and its settings land where you drop them. Drag the grip beside a control to reorder it.
  • Click ✎ on a control to rename it, group it, set its width, range and step, or hide it from the OUTPUT view
  • Follow edited node (in RUN GRAPH’s menu) moves the graph to show the node a control just changed
The OUTPUT view shows the workflow’s result full size. Switch between GRAPH and OUTPUT on the toolbar.
  • The result can be an image, a video, or a 3D view you can orbit in Shaded, Arctic Clay or Wireframe
  • Show original compares the result with the image you started from, and you can download the result from the toolbar
  • Choose which node is the main output from that node’s menu. Show main output on the toolbar takes you to it.
  • With controls and OUTPUT, a workflow works like a simple app: change the controls and press RUN GRAPH. Open in Nodes on a rendering whose workflow has controls opens it straight on OUTPUT.
Any setting can take a wire:
  • Drag a wire onto any setting and it uses the incoming value. The setting shows the value it receives.
  • Drag out from a setting’s socket into empty space to create a Number slider, Toggle, Choice or Seed node that is already set up and wired in
  • Math computes a number from up to four inputs, for example a * 2 + 1
  • Alt-click a socket to remove its wire
:triangular_ruler: Live 3D Geometry
The geometry nodes build 3D models on your computer as you change their settings. They are live and free.
  • Building is a parametric building. Its width, depth, height and other dimensions are settings, so they can be sliders in CONTROLS. From scene… brings in a model from a scene in your Gallery that the MODEL tab’s agent built, and the Nodes agent can write Buildings too.
  • Box, Extrude, Boolean, Array and Transform make simple solids, then combine, repeat, move, turn and scale them
  • 3D Preview shows the geometry in a small 3D viewer inside the node. Double-click it to expand it. The view you orbit to becomes a camera you can wire into other nodes.
  • Capture View turns the geometry into an image, from the preview’s camera or a preset view. Wire it into the Image Generator to render massing studies while you move the sliders.
  • Save 3D Model saves the geometry to your Gallery as a GLB
:brick: Bake from NODES — Revit, Rhino and SketchUp
Inside your host, the Outputs nodes bake a 3D model straight into the open model.
  • Bake to Revit places the model as a family at the internal origin
  • Bake to Rhino places it as a block at the origin, either as full geometry or as a lightweight proxy
  • Bake to SketchUp places it at the origin, either as full geometry or as a proxy
  • Revit and Rhino: keep the model’s own size or scale it to a height you set. Running the node again replaces the previous bake instead of adding a copy.
  • One graph, from photo to model. Wire in a 3D Generator, a 3D Model input or Save 3D Model to generate an asset from a photo and bake it.
NOTE: Each bake node is listed only inside its own host, so Bake to Revit appears only in Revit.
:books: Workflow Library
  • Workflows save automatically to the cloud as you work. There’s no Save button to remember.
  • The workflow pill at the top of the pane opens your library, with Recent and My Workflows, as a grid or a list
  • Save to My Workflows keeps a workflow, and Revert to saved takes you back to the saved version
  • Version history. Veras saves a version each time you run, when the agent finishes and when you save, so you can go back to an earlier one.
  • Rename (or let Suggest a name name the workflow for you), Duplicate, Delete
  • Share a workflow, and use Import share to open one someone sent you
  • Uploads travel with the workflow. Images you upload are saved with it, so it opens the same way on any computer.
  • Renderings remember their workflow. Open in Nodes, in the Gallery’s expanded view or on the workspace strip, reopens the workflow that made the rendering
:framed_picture: The Workspace Strip
  • In NODES, the strip shows everything your workflows made in one row: images, videos and 3D models, with the newest at the end
  • Drag thumbnails to reorder them, or drag an image or video onto the canvas to use it as an input. Double-click a thumbnail to open it full size, and use ← / → to step through
  • Fold the strip away on any tab. Move the pointer near the strip’s top edge and click the small triangle that appears.
More Improvements
  • Fewer “Session is not active” interruptions. A brief hiccup in the sign-in service no longer ends your Veras session, and Veras retries in the background. NODES reconnects your session on its own before it starts a node. The MODEL tab’s agent waits out a sign-in outage instead of stopping.
  • Very large images now save to the Gallery. Large results such as a 4K Post Process image are no longer refused for their size. If a save does fail, a message tells you why.
  • SketchUp: fixed “Bake chunk out of order” errors when baking after the Veras window had been opened a second time. Update the Veras SketchUp plugin to 5.3 for this fix.
Veras - Release 5.3.1.0
New Features
Agent: Replay a Session
  • In MODEL’s Agent pane, choose Replay current session from the ⋮ menu to play the session back quickly, turn by turn, with the model building up in the 3D view. It’s handy for screen recordings and for showing how a model came together
  • A replay sends nothing and costs no credits. Press Stop at any time, and your model and chat come back exactly as they were
  • Replayed elements show flat colours rather than their materials
Agent
  • You can now select and copy text in the agent’s activity log (your messages, its reasoning and its replies) in MODEL and NODES
  • Your free launch-promo credits are now easy to spot: a pill beside the Model picker in MODEL, and beside the agent’s heading in NODES, shows how many you have left and until when. The first time you open MODEL during the promo, a short announcement explains it
Bug Fixes
Workspace
  • Pressing Delete no longer deletes a render from your workspace, on any tab. With masks, sketches and objects all selectable on a render, it was too easy to lose one by accident. Use the trash icon instead
NODES
  • Pressing Delete or Backspace in the expanded render view no longer deletes the selected nodes in the graph behind it
  • Ctrl+Enter now runs the graph only while RUN GRAPH is showing, and a click that lands on STOP just as a run finishes no longer starts a new paid run
Veras - Release 5.3.2.0
New Features
  • Source, Rendered and Original in One Switch
    • The toolbar’s view buttons are now one three-part switch at the start of the toolbar. Source shows what your Source holds, such as your host’s view or an uploaded image. Rendered shows the selected rendering, and Original shows the image that rendering was made from
    • Hover over a part to see what it will show. A part with nothing to show yet is greyed out, and its tooltip says why
    • For a video made from a first and last frame, the caret beside Original chooses which of the two it shows
    • The L and O keys jump to Source and Original
  • Clearer message when a render fails
    • If the render engine can’t finish a render, Veras now says so in plain words, confirms that any credits reserved for it were returned, and suggests trying again. This replaces a technical status line that didn’t tell you what to do
  • Staying signed in
    • If your sign-in has expired when you start an image render, check your credit balance, message the agent or run a node in NODES, Veras now renews it and tries again instead of failing
    • Enscape, Corona and other Chaos apps: when the app renews your sign-in, Veras now picks it up in place, instead of resetting as if it had been closed and reopened. Veras also asks the app for a fresh sign-in shortly before the current one runs out, and whenever a request is refused because it has expired
  • Faster tooltips
    • Most tooltips now open after half a second instead of a full second
Bug Fixes
  • Enscape
    • Select by Material and Select by Object in the mask menu no longer also select unrelated materials or objects with a similar ID color, such as trees and plants picked up along with a sidewalk
  • Revit and Rhino
    • The links in About Veras (Customer Support, Content Enablement and the others) open in your browser again. Install the Veras 5.3.2.0 Windows installer for this fix
  • Uploads
    • After you remove an uploaded file, choosing the same file again now loads it
Veras - Release 5.3.3.0
New Features
Veras in Your Language
  • Veras now comes in ten more languages: German, French, Italian, Spanish, Dutch, Polish, Portuguese (Brazil), Japanese, Simplified Chinese and Korean
  • Choose one under Settings → General → Language. Each language is listed in its own name (Deutsch, Français, 日本語…), and Veras switches straight away, with no restart
  • Automatic, the default, follows the language of your browser or computer, and uses English when Veras doesn’t offer that language. Choose English (US) to keep Veras in English
  • Dates and numbers follow the language too, and credits go by the same name that Enscape uses in each language
  • Buttons, menus and tooltips make room for longer words, so labels stay inside their controls in every language
  • Text that isn’t translated yet, and messages that come from your design app, show in English
NOTE: The translations are new. If something reads wrong in your language, let us know here on the forum.
Veras Is Now a Tab Inside Enscape
(Enscape 4.22 and newer)
  • In Enscape 4.22 and newer, Veras opens as a tab inside Enscape, beside Enscape’s own renderer, with an interface redesigned to match Enscape
  • Navigation is a slim side bar of icon tabs, with Settings and Account at its foot opening as side panels, and the toolbar stands as a vertical rail between your settings and the view
  • Settings sections can be collapsed to keep the panel short
  • The workspace strip gains Renders and Favorites tabs, a New workspace button, and a loading card for each render in progress
  • Menus and tooltips open over the panel, never over your Enscape view
  • Older Enscape versions keep the current Veras window and layout
Enscape Live: Render Straight From Your Live View
  • Veras now shows your live Enscape view in its main view, and the Enscape source renders exactly what you see: move the camera in Enscape and render, with no preview to refresh
  • Enscape is the default source when Veras opens inside Enscape
  • It works in VIDEO too, for the first frame, the last frame, or the start frame of a video edit. When both frames use it, the Enscape drives toggle picks which frame follows your live view while the other keeps the view you left it on
  • MODEL
    • The Split layout button, beside 2D and 3D, is now an icon. Hover over it to see its name
  • Lighter asset bakes
    • When you bake a generated or imported 3D model into Revit, Rhino or SketchUp, Veras now bakes a lighter copy of about 10,000 triangles. A dense generated mesh is far less likely to slow your model down or be refused for its size, and the model in Veras keeps its full detail. Models from Chaos Cosmos are lightened only when they’re too heavy for your design app to take
    • Update the Veras plugin to 5.3.3.0 so that Veras keeps showing a baked model at full detail
Notes
  • Signed by Chaos
    • The Windows installer and the Veras plugins for Revit, Rhino, Vectorworks and Archicad are now signed by Chaos Software (CHAOS SOFTWARE EOOD) instead of EvolveLAB. If Revit asks whether to load Veras after you update, choose Always Load
  • Updating
    • The languages are already in Veras in every design app, with no update needed
    • For Veras as a tab inside Enscape, update Enscape to 4.22
    • Install the 5.3.3.0 Windows installer for the Chaos signing, the lighter asset bakes above, and the fixes from 5.3.2.0, such as the About Veras links opening again in Revit and Rhino. On a Mac, update the SketchUp plugin for the lighter asset bakes
