Helix Door Import Error Revit
@Elliottk Thanks for following up! Unfortunately no, I’m still working on this one, but it’s proving particularly tricky!
I haven’t been able to reproduce this issue in my testing - when I use the Revit and SketchUp models you sent me, the exterior doors show up and stay in the correct place in Revit.
I suspect this may be related to one of the 3 issues from your other thread, and I’m still working on finding a fix for all of those. Once We have a fix, I’m curious if that fix will also solve this issue. Once a working update is released, I’ll let you know so you can test it again and see if it fixes this issue too.
Thanks for your patience!
